Activity Forums Adobe Premiere Pro HVR 10MU drivers
  • HVR 10MU drivers
    Posted by Harvey Zinc on May 18, 2005 at 2:25 am
    Having trouble using the HVR10MU to output DV via firewire into Premiere 6. Drivers recognize the Z1U but not the HVR10MU. Any suggestions on getting drivers for this device?
    I rented it for a day of logging and digitizing as the camera is out most of the day.
    Any help appreciated.
    HZ
    Harvey Zinc replied 21 years, 4 months ago 3 Members · 3 Replies
  • Ken Adolph
    May 18, 2005 at 3:28 am
    You are probably going to have problems until you upgrade to PremierePro 1.5.1
    Ken Adolph
    Media Group
    Editor/Post Supervisor
    https://www.mg.ca
  • Steven L. gotz
    May 18, 2005 at 4:56 am
    Are you certain you have set the deck to convert to DV?
    Steven
    Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
    Learning Adobe Premiere Pro 1.5 https://www.lynda.com
    Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5
  • Harvey Zinc
    May 21, 2005 at 2:48 am
    Yes I had the convert to DV set. Never got it to work so did the old labourous work around. Captured via s video with burn in timecode and manually entered the correct TC and reel numbers.
    Thanks to all
    HZ
