Activity Forums Apple Final Cut Pro Legacy HV20 25p & FCP
  • Posted by Gabriele Gismondi on June 30, 2010 at 3:44 pm
    thanks to Your advices i finally managed to get my hv20 25p footage into FCP.
    I had to set HDVi50 preset so i’m a little confused about which settings should I set my sequence to in order to work and export a HDV25progressive material.
    It looks like FCP sees my clips as interlaced..
    thanx
    Jerry Hofmann replied 16 years, 2 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    July 2, 2010 at 2:43 pm
    Put one of the clips in a sequence and let FCP conform it’s settings to that clip automatically. It should ask you if you want the settings to match the properties of the clip you put in there. If not, then set this to happen in your User Prefs.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski.
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
