Activity › Forums › Adobe After Effects › Hue and saturation based desaturation
  • Hue and saturation based desaturation
    Posted by Ryan Hill on June 18, 2006 at 11:52 pm
    I want to do a selective desaturation.
    I know about Leave Colour, but it isn’t complex enough to do what I want to do. (At least not on its own)
    I want to desaturate slightly, except for colour of a certain range of hue, and only for mid to low range of saturation. (IE: very bright colours will remain very bright, but sort-of bright colours will be dimmer, and dim colours will be grey)
    What should I use to do this?
    Ryan Hill replied 20 years, 3 months ago 3 Members · 5 Replies
  • Justin Productions
    June 19, 2006 at 1:03 am
    I fairly think that Adjust > Curves would be the perfect effect for this.
    Maybe I’m wrong, but it’s my opinion.
    Hope that helped.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Andrew Kramer
    June 19, 2006 at 1:23 am
    can’t you just use the “hue and saturation” effect, just change the chanel and change the range that you want of color, then adjust…
    Andrew
  • Ryan Hill
    June 19, 2006 at 2:05 am
    Huh. I never noticed that part. Hue/saturation is much more complex than I remembered. Maybe I can get it to do similar to what I’m looking for.
  • Ryan Hill
    June 19, 2006 at 2:28 am
    So I duplicated the layer three times.
    I used hue/saturation on the middle layer, selected a large portion of the hue spectrum and desaturated that. Then, so it wouldn’t desaturate very saturated things, I used shift channels on the top layer so RGB was replaced with saturation. Then I used it as a track matte on the desaturated layer. I tweaked all of this with levels at various places, most importantly on the top layer. And we’re good.
  • Ryan Hill
    June 20, 2006 at 12:17 am
    Oooh. And I found another nice tool, Channel Combiner, which I could use to convert RGB to HLS, apply curves like Justin suggested, then convert back again.
