Activity Forums Web Design (WordPress, Joomla, etc.) HTML coding – user option to choose HTML or FLash site
  • HTML coding – user option to choose HTML or FLash site
    Posted by Rory Townsend – seddon on May 13, 2010 at 10:12 am
    I require the HTML coding to allow the user to choose whether they enter either my HTML or Flash site via buttons or similar.
    Also please could I have the HTML code to automate the process if the viewer can’t play flash (i.e. on an iphone etc) and it automatically forwards them to the HTML page.
    I haven’t decided which is more appropriate yet so will test with both options.
    Thank you in advance for your time.
    Fernando Mol replied 16 years, 4 months ago 2 Members · 1 Reply
  • Fernando Mol
    May 13, 2010 at 4:42 pm
    You can insert your swf using swfobject and if the user doesn’t have the flash player, the browser automatically displays the html code you inserted using this tool.
    You download the swfobject generator, open it and select from different options. You can insert your alternate html code there, then generate the final code that will display your swf file or the html version.
    https://code.google.com/p/swfobject/
    I hope this helps
    *Always share a link to your site and rate the posts. This is a free service for you and for us.
