Activity › Forums › Compression Techniques › HSN – 720p/60 to ProRes HQ 1060i/29.97
  • HSN – 720p/60 to ProRes HQ 1060i/29.97
    Posted by Peter Tours on April 22, 2011 at 6:52 pm
    I have an FCP sequence that is DVCPRO HD 720p/59.94 and HSN’s specs are ProRes HQ, Interlaced, 1980×1080, Top Field First, 29.97df.
    I have Compressor (latest) and Media Encoder CS5.
    How do I get there? I thought ProRes was a “pass thru” codec…?!?!
    Thanks for any help.
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to infinity and beyond!
    Peter Tours replied 15 years, 5 months ago 2 Members · 2 Replies
  • Rich Rubasch
    April 24, 2011 at 4:47 pm
    I would export directly out of the FCP timeline and choose ProRes HQ and be sure to check the interlaced box and set it to Upper Field. Then specify the framerate as 29.97.
    In the Size checkbox, make it 1920 x 1080. Set Audio to 48k PCM and you should get a perfectly passable clip….a large one, but should pass QC.
    Rich Rubasch
    Tilt Media Inc.
    Video Production, Post, Studio Sound Stage
    Founder/President/Editor/Designer/Animator
    https://www.tiltmedia.com
  • Peter Tours
    April 24, 2011 at 5:04 pm
    Thanks – I wound up watching some tutorials and basically did the same thing you suggest, just in Compressor. I have been spanked before about exporting from FCP compared to Compressor. I chose the uncompressed preset in HD, changed the codec to ProResHQ and did just what you said.
    Now I know – I hope someone needs it again before I forget!
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
