Activity Forums AJA Video Systems Hs vs LHe
  • Hs vs LHe
    Posted by Brian Scott on May 29, 2008 at 3:49 pm
    I’m looking at a new I/O card for use with Premiere and After Effects CS3. All my signals are SDI. What are the pros and cons of the Hs and the LHe?
    Brian Scott
    President
    Image Design Productions, Inc.
    Thad_h replied 18 years, 2 months ago 3 Members · 2 Replies
  • Tim Kolb
    June 3, 2008 at 2:45 am
    Just in case you didn’t see my response on the Premiere forum…
    The HS card was designed as an “OEM” card really…something that could be (relatively) inexpensively bundled with certain software and/or hardware to get HDSDI I/O on a system…
    The HS card does NOT have:
    HD analog component I/O
    SD analog component or composite/YC I/O
    Hardware HD to SD downconversion (I use this all the time)
    Native support for DPX, Cineon, TGA, TIFF, BMP sequences
    2 independent SDI/HD-SDI outputs (The HS card has only 1)
    2-channel balanced XLR analog audio I/O
    RS-422 machine control
    AJA Machina software
    For the money, I think the LH/LHe cards are a better return on investment for a general-purpose editing suite that may switch back and forth between SD/HD…uncompressed/compressed, etc…
    In a very narrow application where you knew you’d always only need digital HD I/O…the HS would probably be fine.
    TimK,
    Director, Consultant
    Kolb Productions,
    CPO, Digieffects
  • Thad_h
    June 12, 2008 at 10:39 pm
    Brian,
    Really if you are going to be using After Effects primarily and all HD-SDI you should choose between the HS and the XENA 2K or 2Ke. These cards will give you the highest framerates of RAM preview output.
    Also the XENA HS is PCI-X only, so if you are looking for a PCI-Express, you should probably opt for the 2Ke.
    AJA XENA Suppport
