Activity › Forums › Panasonic Cameras › HPX-3700 and a HPX-3100
  • HPX-3700 and a HPX-3100
    Posted by Michael Shugrue on May 16, 2011 at 4:55 pm
    After reading the specs on these cameras, am I wrong or can I match a 3700 and a 3100 in 1080p 23.98 ?
    Besides not doing 4:4:4 and having 5 slots over 2 slots ? What am I missing ?
    Wolf Austad replied 15 years, 4 months ago 2 Members · 1 Reply
  • Wolf Austad
    May 20, 2011 at 6:21 pm
    You are not missing anything. These cameras should be possible to match in 1080/23.98. As long as you don’t need 4:4:4, 24.00fps, 23.98/24.00 system setting, P10log output, variable frame rates, etc. that are 3700 only features (as you mention)
    I’ve used both quite a bit, and the 3100 has some sort of noise reduction built in (adjustable) + a newer CCD so you might need to work the matrix a bit to make them look the same.
    Might also want to dial ‘down’ the new improved audio bit rates of the 3100 to match the 3700 audio format.
    Aasulv Wolf Austad, fnf
    Director of Photography
    Los Angeles based
