Activity Forums Panasonic Cameras HPX-301 (UK) 300 (USA) black dot noise
  • HPX-301 (UK) 300 (USA) black dot noise
    Posted by Philip Johnston on May 13, 2009 at 12:03 am
    I was reviewing the Panasonic HPX-301 when I came across black dancing dots at 9dB. I have had to suspend the video review till I get answers from Panasonic Japan if they can do anything about this unacceptable noise. Today a college and myself looked at -3dB and 0dB to discover the noise is still there in the shadows. You can’t possibly make any HD top notch production with this camera as it stands at the moment I only hope Panasonic Japan can do something about this.
    “Setting the standards for others to follow” http://www.hdwarrior.co.uk
    Philip Johnston replied 17 years, 3 months ago 4 Members · 12 Replies
  • 12 Replies
  • Jeremy Garchow
    May 13, 2009 at 4:31 am
    Can you post a second or two of a ProRes file?
  • Vince Becquiot
    May 18, 2009 at 4:40 pm
    Ever figured out the issue. Looking at getting the camera and I am looking for any potential issues.
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
  • Philip Johnston
    May 18, 2009 at 5:47 pm
    Firstly Jeremy, this does not show up viewing it on an LCD less than 40″.
    Vince I have been assured by Panasonic that they are going to get to the bottom of this issue, so my advice is as follows…
    1. Do not buy from a box pusher
    2. Buy from a official Panasonic dealer
    3. You are paying $10K or above so ask the dealer for a test drive
    4. If you can only test drive in the dealers premises make sure they have an HD-SDI 40″ LCD that you can view the pictures from the camera.
    5. Stick the camera to 720 60P and film darkish areas at 9dB
    6. Look back at the footage…you will not miss the dancing dots if they are present.
    Note. The dots do not show up in DV mode.
  • Jeremy Garchow
    May 18, 2009 at 6:45 pm
    9db seems a bit high to me, but perhaps you are shooting in low light.
    Can you post a few seconds (it’s ok if you can’t) i’d love to see what it looks like.
    Jeremy
  • Philip Johnston
    May 18, 2009 at 7:34 pm
    Jeremy this will link you to my blog on the “Black Dot Problem” then you will find a link to a full 13MP picture of the problem. Sorry the last link was corrupt.
    https://www.hdwarrior.co.uk/2009/05/11/update-on-the-panasonic-hpx-301-dancing-black-dots/
  • Vince Becquiot
    May 18, 2009 at 8:03 pm
    Couldn’t follow the link but found the still on the site. While we almost never make use of gain, I’d be interested to know, if this only happens with AVC Intra?
    Vince Becquiot
    Kaptis Studios
  • Vince Becquiot
    May 18, 2009 at 8:06 pm
    Also, does it happen whether you are on battery or on AC?
    Vince Becquiot
    Kaptis Studios
  • Philip Johnston
    May 18, 2009 at 8:13 pm
    I checked with AVC and without, as you say if you do not use gain you should be fine. I see where you are coming from but sadly both mains and battery.
  • Jeremy Garchow
    May 19, 2009 at 6:58 pm
    Do you have a depth of field adaptor on there?
  • Philip Johnston
    May 19, 2009 at 7:53 pm
    Do you mean a 35mm Letus or similar…NO.
