Activity Forums Blackmagic Design HP Dreamcolor + hdlink 3d & Decklink extreme 3d = Cailbration?
  • HP Dreamcolor + hdlink 3d & Decklink extreme 3d = Cailbration?
    Posted by Sean Kapleton on November 2, 2010 at 2:44 pm
    Hello
    I am about to pull the trigger on a home 12-core setup for color correction (color & Davinci) and want to use a Dreamcolor with an Extreme 3d & hdlink 3d but if this is true and a proper adapter does not exist for display port to hdmi 1.4a then we have a problem!
    I am curious in comparison to the AJA HDP2 if I am using a Dreamcolor is that hdmi 1.4a or only 1.3? Is there any difference between the e2 converters?
    Also does anyone know what settings i should have in the hdlink 3d utility for use with the Dreamcolor (rec. 709)?
    sean
    Manuel López replied 15 years, 10 months ago 2 Members · 6 Replies
