Activity Forums Apple Final Cut Pro Legacy How would you handle this RED situation?
  • How would you handle this RED situation?
    Posted by Paul Factora on June 26, 2008 at 1:21 am
    Client has provided me with 156 folders of RED qt’s.
    Half footage was shot at 24fps. The other half are at 59.94. %^\
    I’m thinkin the 59.94 files are for slowmo effects.
    Can the FCP timeline support 2 different fps? Is there a specific process I would use to batch slowmo all the different clips?
    Also, is there a workflow posted regarding FCP workflow when working online and offline on RED files?
    Thanks in advance,
    -p
    fcp 6.03
    Macbook Pro 2.4 duocore 2gb Ram
    10.5.3
    Sean Oneil replied 18 years, 3 months ago 2 Members · 3 Replies
  • Sean Oneil
    June 26, 2008 at 6:18 am
    What’s your final output going to be? 60 or 24? You also ask on the RED forum
    Sean
  • Paul Factora
    June 26, 2008 at 8:06 am
    60.
    Never knew there was a Red forum. LOL thanks.
  • Sean Oneil
    June 27, 2008 at 8:32 am
    If it’s 60, then you probably just want to edit all your footage on a 59.94 sequence. FCP6 allows this. The 23.98 footage will just playback with 2:2:2:4 pulldown.
    Sean
