Activity › Forums › Adobe After Effects › How would you go about producing this animation?
Posted by Olly Lawer on December 8, 2011 at 10:04 pmI can think of a few ways, but not to prejudge what others think, what way would you go about it?
https://www.youtube.com/watch?v=zDZFcDGpL4U&noredirect=1
Kind regards,
Olly Lawer
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Mike Moon replied 14 years, 2 months ago 5 Members · 16 Replies -
Angelo Lorenzo
December 8, 2011 at 10:15 pmGreen screen with glass or acrylic laid on top. Green dry-erase marker. The actor adlibs the drawing to an already animated sequence of hand drawn images and computer drawn text and strokes. The actor’s hand is then keyed and overlaid with the animation. Done deal.
Olly Lawer
December 8, 2011 at 10:23 pm[Angelo Lorenzo] “Green screen with glass or acrylic laid on top. Green dry-erase marker. The actor adlibs the drawing to an already animated sequence of hand drawn images and computer drawn text and strokes. The actor’s hand is then keyed and overlaid with the animation. Done deal.”
OK. So just to be clear about it then.
1. When the hand comes in to adlib, won’t that create a shadow, thus complicating the keying of the green?
2. You think all the images AND text are animated and not drawn?
3. Where the image seems to be ‘drawn’ you think shots (I guess high quality images taken on a high end still camera) where taken at various points of the drawing (without the drawers hand obviously) and then these inserted into the time-line in sequence until the drawing is complete?
4. The adlib hand is then matched to make it look like it is drawing it?
Sorry for all the questions!
Olly Lawer
Olly Lawer
December 8, 2011 at 10:24 pmPS – How long would it take to produce something like this?
Olly Lawer
Kevin Camp
December 8, 2011 at 10:39 pmget a big white board, higher an illustrator and set up a digital still camera to shoot time-lapse.
then in post, zoom and pan as needed to keep the action in frame.
and at some point before the shoot, plan, plan, plan….
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Olly Lawer
December 8, 2011 at 10:42 pm[Kevin Camp] “get a big white board, higher an illustrator and set up a digital still camera to shoot time-lapse.
then in post, zoom and pan as needed to keep the action in frame.”
This is what I was thinking to be honest, but the hand drawing would need to be adlib wouldn’t it – otherwise the drawing wouldn’t come across smooth like it does on this animation?
Olly Lawer
Kevin Camp
December 8, 2011 at 10:52 pmwith strong lighting and maybe clipping the highlights in post, i think you could get away with a light pencil sketch and have minimal masking out to do in post.
you’d also need to keep watching to make sure the artist keeps his/her head back….
Kevin Camp
Senior Designer
KCPQ, KMYQ & KRCW -
Angelo Lorenzo
December 8, 2011 at 10:56 pmDave swooped in and clarified my answers.
How long would it take to produce something like this? I would say it’d take an artist and a digital editor about 3-4 weeks for something of this length. In my mind this encompasses dealing with a client so some time will be spent doing a few versions of rough edits/previsualization and so forth.
I guess I should say I’ve cheated a little bit. I bid a job for a perspective client who wanted the exact same thing about 8 weeks ago.
Olly Lawer
December 8, 2011 at 11:05 pmCool.
I’m still not entirely convinced I know how to achieve this. But I will mull it over – it is late 🙂
I get that you can take a series of still of the drawing as it is completed and zoom in. Easy.
Then when you add in the hand for the adlib, you need to match that up with the sequence of stills you are going to use when ‘drawing’ the object. So if, lets say a character for example, is animated from the stills into 4, 1. the left leg, 2. left leg + torso and left arm, 3. left leg + torso, left arm and head, 4. left leg + torso, left arm, head and right arm and leg. So the adlib hand needs to draw in THAT sequence, otherwise the hand/pen won’t follow the sequence of stills – right?
Now, if I stencilled out the drawing on a white board and lit it well so you couldn’t see it, it would be easy for the hand to come in and adlib in that sequence, but I would have to key out the hand manually. So the only way to do that would be to use a green screen, with glass on top and already have the drawing stenciled out in green pen which the hand adlibs. So then I can just key out all the green and place the sequenced still images below it – right?!
Olly Lawer
Olly Lawer
December 9, 2011 at 12:23 am[Dave LaRonde] “[Olly Lawer] “1. When the hand comes in to adlib, won’t that create a shadow, thus complicating the keying of the green?”
Not if you build a rig above the chroma key background that holds the clear panel firmly in place. You’d also have to think about reflections of he hand. Excellent lighting, testing and a bit of rotoscoping are all key. I don’t know if it’s necessary to have a green marker.
[Olly Lawer] “2. You think all the images AND text are animated and not drawn?”
Yes. You’ll note that in several places, the material being “drawn” on magically changes color although the marker keeps drawing.
[Olly Lawer] “3. Where the image seems to be ‘drawn’ you think shots (I guess high quality images taken on a high end still camera) where taken at various points of the drawing (without the drawers hand obviously) and then these inserted into the time-line in sequence until the drawing is complete?”
Or a meticulously-prepared series of Illustrator layers, where revealing the visible portions is animated. That’s an extremely consistent-looking white background, which leads me to believe it’s just that: a background, and not paper.
[Olly Lawer] “4. The adlib hand is then matched to make it look like it is drawing it?”
Yes. You’ll notice the hand leaves the shot before the illustration ever moves. That way, it’s easier to position the hand on the shot. Each chroma key shot is a prescribed action, no doubt rehearsed a time or two. Or ten. Perhaps even with the aid of the actual graphic being onion-skinned over the chroma key shot in a monitor to aid the director & talent. I doubt this was done just by rolling a camera and hoping for the best.”
Sorry – just saw this – thanks. I think I get it now 🙂
Olly Lawer
Olly Lawer
December 9, 2011 at 12:25 amOn a note of price.
If one of you were to produce this for me, what would be the cost and what would you need from me?
Kind regards,
Olly Lawer
