Activity › Forums › Adobe After Effects › how would one make the pink and white background in this link?
Posted by Jamie Nabers on September 14, 2006 at 3:29 pmMohamed Hafeez replied 17 years, 5 months ago 6 Members · 6 Replies -
Mylenium
September 14, 2006 at 3:46 pmThere’s a bazillion ways to do this, but for simplicity’s sake I suggest you take a look at my “Sun” tutorial here at the COW. It contains everything you might need, you only need to adapt it to your needs.
Mylenium
[Pour Myl
Serge Hamad
September 14, 2006 at 3:57 pmHi,
There are many ways to create this one. Here is one:
-Create a large layer (1000 X 1000) for instance.
-Apply Venetian Blind with a transition value of (55%) and (42) width value.
-Apply Polar coordinate at (100%)interpolation value Rectangular to Polar
-Apply now the Optic Conpensation filter at around (90) for the FOV Check the RLD box and move the View Center point to where you want.Salut.
Serge -
Justin Productions
September 14, 2006 at 4:44 pmWow! thank’s a bunch Serge! Wuhu!
Justin Productions
Tangerin01@hotmail.com
Adobe After Effects 6.5 Professional -
Sean Corcoran
September 14, 2006 at 6:11 pmAnd for yet another option, use Zaxwerks’ GradientWerks plug-in. I just used it this morning on a project.
Jamie Nabers
September 17, 2006 at 12:23 amthanks guys,
you are what makes this site as good as it is !!!!
j
Mohamed Hafeez
March 16, 2009 at 2:39 pmVery Old thread but still I thought I will add one more way to do this to the existing million ways 🙂
1. Draw a Star Shape layer (center it)
2. Increase Points > 20
3. Inner Radius = 0
4. Outer Radius = Large value to cover your solid
5. Adjust the inner and outer roundness to make it look flat
6. Lo! Sun Burst 🙂And since this is shape layer then probably you can do more magic.
PS: I think the initial question may not be valid as I am not sure if Shape layers were there in 2006 version of After effects. I started from CS3
