Activity Forums Boris FX Particle Illusion how would I do this?
  • how would I do this?
    Posted by Rinny8 on November 25, 2005 at 3:45 pm
    I want an effect to circle around someone. How would I make it so that the effect (say an orb) goes behind the person on one side, comes back on the other side and goes in front of them? I can’t use the blockers cause they block it no matter what.
    Grant Barker replied 20 years, 9 months ago 3 Members · 3 Replies
  • Alan Lorence
    November 25, 2005 at 3:50 pm
    https://www.wondertouch.com/tutorials/around_01/around.htm
    If you don’t have the person masked out (with an alpha channel), you can still use blockers. Just put the “front” emitter on a different layer.
    Alan.
    wondertouch
  • Rinny8
    November 25, 2005 at 4:36 pm
    thanks
  • Grant Barker
    November 30, 2005 at 3:38 am
    Also, if you have Adobe After Effects, you can split the layer. (at the point where you want to seperate the infront and behind parts).
