Activity › Forums › Adobe After Effects › How was this done?
  • Jim Arco
    February 18, 2010 at 1:29 pm
    The zooms appear to be done in post-production and cover the cuts between scenes. There is also some masking/feathering where the “cuts” don’t quite match up.
    You could probably do something like it yourself by shooting the first part of a scene, moving the camera, then restarting the lip-sync a few seconds earlier when shooting the next ‘scene.’ Then you’d need to piece it all together in post.
    That…..and lots and lots of planning.
  • Ed Palomino
    February 18, 2010 at 9:12 pm
    You should take a look at Andrew Kramer’s Earth Zoom tutorial
    https://videocopilot.net/tutorials/earth_zoom/
    Its not exactly what you’re looking for, but I believe the principles are there. The only difference is instead of using still images you’re using clips. So like the other guy said, just plan it out.
