Activity › Forums › Adobe After Effects › How to zoom out off a map with video clips?
  • Kalleheikki Kannisto
    August 16, 2016 at 1:57 pm
    As I (vaguely) recall, there was a master null (or layer) for scale that everything was parented to. Did you parent the videos to the same?
    Senior Graphic Designer
  • Nitai Lev-oren
    August 16, 2016 at 4:07 pm
    yes I attached all the clips to a null object but I don’t want the clips nor the comp will be 3d
    here is a pic:
  • Nitai Lev-oren
    August 16, 2016 at 6:59 pm
    and here is a video from what I see:
    https://screencast.com/t/4THUaN9fnZo
  • Nitai Lev-oren
    August 18, 2016 at 11:00 am
    up
  • Rex Payne
    August 18, 2016 at 4:46 pm
    August 19, 2016 at 6:34 am
    The only problem I see is that the videos are not connected to the main null.
  • Nitai Lev-oren
    August 19, 2016 at 10:32 am
    videos you mean the v.clips on the map or the map pics PNG files?
    August 19, 2016 at 3:32 pm
    By video I mean video. “Clips2” is parented to “clips” and “clips” is not parented to anything. Whichever layer contains your video clips — or both — should be parented to “null6” if that’s the master scale null.
