Activity › Forums › Apple Final Cut Pro Legacy › How to zoom in on a person?
Posted by Bernard Ageeb on September 24, 2007 at 2:44 pmI have a wide shoot HD which 3 people in and i want to zoom in to one person. Will it keep the HD quailty? How can i do this in FCP? Thanks inadvance
Bernard
Dan O’brien replied 19 years ago 6 Members · 5 Replies -
Walter Biscardi
September 24, 2007 at 3:25 pmYou simply use the Motion Tab for this. Scale and Center are the two controls you’ll need to use. You can set keyframes for the movement.
There is a Final Cut Pro Basics forum and I’m sure you can do a search in there to find a more complete description of how to do this.
Walter Biscardi, Jr.
HD Editorial & Animation for Broadcast and independent productions.All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
Read my blog! https://blogs.creativecow.net/WalterBiscardi
Arnie Schlissel
September 24, 2007 at 4:03 pm[Bernard] “Will it keep the HD quailty?”
No. You picture will look less sharp, or may pixelate if you zoom in too far.
Arnie
Now in post: Peristroika, a film by Slava Tsukerman
https://www.arniepix.com/blog -
John Czerwinski
September 24, 2007 at 4:13 pmwhat do you think is the maximum you can zoom in on HD footage?
Andrew Kimery
September 24, 2007 at 5:14 pmHow far can you zoom in?
It depends on the quality of the footage. Just watch your footage on an HD monitor and keep zooming in until it starts looking bad and then you’ll know how far you can go
-A
Dan O’brien
September 24, 2007 at 8:30 pmtechnically speaking… increasing the size of footage past 100% on any footage will reduce the picture quality. It’s just a matter of how far you want to push it before the reduced quality becomes really noticeable.
So the answer to “how much” depends on each individual I guess.
Dan
PrEditors.net
