Activity › Forums › Adobe After Effects › How to use textSource.style expression with other expression
  • How to use textSource.style expression with other expression
    Posted by Hadi Kot on September 18, 2020 at 2:27 pm
    Simply how i can use this 2 expression all together
    thisComp.layer(“text A”).text.sourceText.style;
    effect(“Slider Control”)(“Slider”);
    right if i get the textSource from slider control value i can’t get the style from other layer
    so how i can do that? thanks
    Hadi Kot replied 6 years ago 3 Members · 4 Replies
  • Hadi Kot
    September 19, 2020 at 4:28 am
    Any help?
  • Jean Baptiste
    September 19, 2020 at 10:34 am
    Hello Hadi,
    You can try to use this expression in a Text Layer “Source Text” field.
    FONT_SIZE = effect(“FONT_SIZE”)(“Slider”);
    text.sourceText.style.setFontSize(FONT_SIZE);
    Attention, you must : Go to File > Project Setting > Expressions, and set the Expression Engine to JavaScript. Otherwise, “text style” expressions won’t work.
    Project sample here
    https://www.dropbox.com/s/4qxgmmd66xtam7p/
    More information on Text Style Expressions here :
    https://helpx.adobe.com/after-effects/using/expressions-text-properties.html
  • Filip Vandueren
    September 19, 2020 at 11:08 am
    Hello Hadi,
    it’s a perhaps bit counterintuitive, but you get the style, and then you apply a setText() method to the style. You can’t take a text (which would be converted a string) and add a style to it.
    so in your case:
    s = thisComp.layer("text A").text.sourceText.style;
    s.setText( effect("Slider Control")("Slider").value );
  • Hadi Kot
    September 19, 2020 at 1:54 pm
    Perfect, that exactly what I want Thumbsup
