Activity › Forums › Adobe Encore DVD › How to use files without enconding?
  • How to use files without enconding?
    Posted by Lucas Kuhn on February 2, 2010 at 6:41 am
    There is a way to use my videos in .avi format?
    I don’t want to convert them because I was going to convert to MPEG 2 DVD and my video goes from 350 MB to an 1000MB estimated.
    I want to put 13 videos of 350 MB avi high quality, but if I need to encode to MPEG 2 I will post only 4 VIDEOS. I’ll pay the triple cost.
    There is a way to use pure .avi to dvds at Encore?
    Jon Geddes replied 16 years, 8 months ago 2 Members · 1 Reply
  • Jon Geddes
    February 2, 2010 at 3:24 pm
    The short answer: No.
    The only codec DVD’s support is mpeg2. You should use a bitrate calculator to find out how much content you can fit on the disc. I wouldn’t encode lower than 4 mbps. I personally don’t encode lower than 5, but 4 might be acceptable for your needs. Remember to use 2-pass VBR encoding.
    If you use a calculator, you will see than at 4 mbps, you can fit approximately 2hrs 20min on a single layer DVD (192 kbps audio).
    If you lower the audio quality to 128 kbps, you can get an extra 4 minutes of video.
    Jon Geddes
    http://www.precomposed.com
