How to Use FieldsKit in Adobe Premiere Pro CS5.5 ?
I’m a beginner and use Adobe Premiere Pro CS5.5. and Fieldkit.
But It does not effect well.
Final Output movie shows the ORANGE CROSS LINE printed ” RE:Vision Effects, inc.”Although, The setup of Premiere is wrong.
I read an FieldsKit instruction manual, but some contents was
difficult and could not understand. what I should do.I probably make a mistake very elementarily.
My setup is written to below.Please tell me wrongs.
(1) My movie is AVCHD of SONY HundyCam. 1080(60i) 29.97fps
Interlace. field Order : Upper first
1920*1080 (1.0)(2) Make new Sequence01 (AVCHD 1080(30)60i) Premere Pro Presetting.
(3) Insert the AVCHD movie to sequence01.
(4) Make more Sequence (It’s name a Sequence02)
Sequence02 is 29.97fps and field is “NONE”(5) Next, Insert Sequence02 to Sequence01
(6) Drag the FieldKit Plug-ins and drop to Sequence01 in Sequence02.
(7) Set the paramaters of FielsKit
*Time Mode = Motion Estimated Blend, 1 Frame Per Frame
*Field Order = Upper First
*Fill Method = Best 5 Neighbors
*Detect Motion = Small Area(8) Encord to QuickTime ProRes422(HQ) by Adobe Media Encoder CS5.5
1920*1080(1.0) 29.97fps , Field Type is “Progressive”I did NOT render on Premiere Pro.
Writeout by only Media Encorder.Please help me.
Thank you.
