Activity Forums Apple Final Cut Pro Legacy How to use FCPs image stabilizer
  • How to use FCPs image stabilizer
    Posted by Jack Pitzer on July 18, 2005 at 8:57 pm
    Greetings, I have a few clips that need to be image stabilized. I’ve tried using the built in filter in FCP, but I can’t seem to make it do it’s thing. When I apply it, it seems like it adds more motion, not less. Can anyone give me any hints on how to make this filter work.
    Thanks much in advance!
    Jack
    Bret Williams replied 21 years, 2 months ago 2 Members · 1 Reply
  • Bret Williams
    July 18, 2005 at 11:35 pm
    Start on the first frame of your clip. Place the center cross hair on something distinct that you want to hold in place. Expand the scan range to a distance that is the most it is going to move between frames. That’s how far it will look for the object you marked with the crosshairs from frame to frame.
    Don’t worry if the best object for the “center” cross hair isn’t actually what you want in the exact center. You can recenter the whole image with the motion tab.
    The bummer with stabilizing is that the more motion you have, the more you have to enlarge your image so that the black edges don’t show. So it’s good for stabilizing a shaky hand held shot, but you can’t turn a pan into a lockoff if you know what I mean.
