Activity Forums Adobe Illustrator How to use 3d image in Adobe illustrator?
  • Vincent Rosati
    October 15, 2009 at 5:06 am
    I realize this is an old thread.
    In illustration, 3D is an illusion.
    You would need a 3D app to create a 3D object.
    You could use Effect/3D on an object. But, it doesn’t actually create a 3D object, it just appears to be 3D.
    You can also use Illustrator to create splines for use in 3D apps.
    Vince
    *Please remember to Rate our replies or check Solution if solved. If you get a good idea from the post, consider clicking the Kudos option.
