Activity › Forums › Adobe After Effects › How To Update Main Comp with PreComp?
  • How To Update Main Comp with PreComp?
    Posted by Ervin Tia on August 30, 2012 at 3:41 am
    Hello. AE, newbee here.
    So, how do you ensure that precomp edits are updated to the main comp?
    I mean, I’ve been using a similar tool before. Just this simple question. I updated the comp size of main comp but when I tried it on the precomp (text/title), i still get the jagged edge on the main comp.
    Thanks.
    Ervin Tia replied 14 years, 1 month ago 2 Members · 2 Replies
  • Roland R. kahlenberg
    August 30, 2012 at 4:03 am
    Precomps (child comps) have a live relationship with their main comps (parent comps). Hence, any updates you make to the child comp will be reflected in the parent comp.
    The description of your issue isn’t clear but I’ll take a guess that you are experiencing pixelation in the parent comp. Depending on what you’re doing and to the type of layer you’re working with the solution will vary. Let us know exactly what you’re doing and to which type of layer (video, vector, raster graphic) you’re applying it to.
    BTW, for newbie Qs, please use the COW’s AE Basics Forum here.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Ervin Tia
    August 31, 2012 at 7:32 am
    It’s a simple text (vector) layer precomp.
