Activity Forums VEGAS Pro how to uninstall expired bcc
  • how to uninstall expired bcc
    Posted by Gilles Gagnon on August 19, 2013 at 1:38 pm
    Hi all!
    in my svp 12, I have remnants or bcc (boris continuum) fx plugins. I can’t remember how /when I installed them but they have expired. I get a message that I must purchase in order to use them.
    I don’t want these effects on my svp config as they clutter my fx list.
    how do I remove them?
    Cheers,
    Gilles
    John Rofrano replied 13 years ago 2 Members · 5 Replies
  • John Rofrano
    August 19, 2013 at 1:47 pm
    You should be able to go into your Windows Control Panel under Add/Remove Software and uninstall them. If they don’t show up in the list, re-install the software to re-establish the uninstaller and then immediately uninstall. Make sure that Vegas Pro is not running when you do this because it may lock the files and mess up the uninstall.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Gilles Gagnon
    August 19, 2013 at 1:52 pm
    Thanks JR!
    Should have looked there first. I see it and will remove as soon as I close my current projects.
    G
    Gilles
  • John Rofrano
    August 19, 2013 at 2:47 pm
    Yea, and you might want to check you Windows Task Manager to make sure that Vegas Pro is not “stuck” in memory even after you’ve closed it. That happens to me sometimes. It’s important that Vegas is not running when you uninstall any plug-ins.
    ~jr
  • Gilles Gagnon
    August 19, 2013 at 8:27 pm
    worked like a charm!
    Thanks jr
    Gilles
  • John Rofrano
    August 20, 2013 at 11:23 am
    You’re welcome. Glad that worked. 🙂
    ~jr
