Activity Forums Adobe After Effects Expressions How to “un-synchronize” a bunch of “jack-in-the-boxes”
  • How to “un-synchronize” a bunch of “jack-in-the-boxes”
    Posted by Sean Siegler on May 2, 2008 at 6:44 pm
    So I am trying to make some text “bounce” on screen, using Dan Ebberts “Jack-in-the-box” expression:
    veloc = 35;
    amplitude = 30;
    decay = 1.0;
    y = amplitude*Math.cos(veloc*time)/Math.exp(decay*time);
    value + [0,y]
    It works just fine (bounce-wise), however, I am applying this to to about 12 lseperate ayers of text, with each layer appearing 5 frames after the previous one.
    I want each layer to bounce in relation to when they appear on screen, however, in this instance, they are all bouncing in synch, as if they were one layer.
    I have tried tweaking this script and the only way I can get them to not all bounce together is to change the decay. However, that doesn’t really work because I want them to have the same motion, just not at the same time.
    I am guessing this is pretty easy to fix, but I can’t seem to get it, so I am here to ask the experts!
    Any advice?
    Sean Siegler replied 18 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 2, 2008 at 7:24 pm
    Do the text layers have different in points? If so, this should work:
    veloc = 35;
    amplitude = 30;
    decay = 1.0;
    t = time – inPoint;
    y = amplitude*Math.cos(veloc*t)/Math.exp(decay*t);
    value + [0,y]
    Dan
  • Sean Siegler
    May 2, 2008 at 7:51 pm
    Yes they do all have different in points, and yes this works!
    I just thought I’d note here that the 1st version you posted (which I got in am email from CC) with this line,
    y = amplitude*Math.cos(veloc*(time-inPoint))/Math.exp(decay*time);
    certainly did the trick.
    However, the version that was posted with this bit,
    t = time – inPoint;
    also works, but makes the bounce much much larger (along the y axis).
    I had tried using “(time-inPoint)” myself, but couldn’t figure out where to put it. Thanks for the help. This clears up much and explains even more.
    -Sean
