Activity Forums VEGAS Pro How to Tweak Patchwork Green Screen with Secondary Color Corrector
  • How to Tweak Patchwork Green Screen with Secondary Color Corrector
    Posted by Casey Menninger on January 7, 2007 at 11:14 pm
    I have been using a “homemade” green screen using a couple of tablecloths. However, one shot needed more “screen” so I hastily threw an old green sheet up to cover an exposed corner, because I didn’t have another tablecloth of the exact kind I was using.
    Mistake.
    Even though it was green, somehow the chroma keyer in Vegas 7.0 won’t eliminate it. It is slightly lighter green than the the tablecloth, but I guess that was enough to make a problem.
    Question: is there a way, using the secondary color corrector, to transform the lighter green of the sheet into the darker green of the tablecloth, so as to have one uniform “tablecloth” color to work with?
    Thanks in advance!
    Metranil
    Mike Kujbida replied 19 years, 7 months ago 3 Members · 4 Replies
  • Gary Kleiner
    January 8, 2007 at 4:23 pm
    Is your subject fairly stationary? If so, it wouldn’t be too hard to create a bezier mask to eliminate most of the background altogether.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Casey Menninger
    January 8, 2007 at 6:11 pm
    Hi Gary,
    Unfortunately, the subjects are not static, but instead are a dancing couple. Slow dancing, but dancing nonetheless…
    Thank,
    Mythreindeer
  • Gary Kleiner
    January 8, 2007 at 9:50 pm
    … and you’ve tried selecting a RANGE of greens with the chroma keyer?
    Gary Kleiner
  • Mike Kujbida
    January 8, 2007 at 10:14 pm
    To elaborate on what Gary is talking about, check out the Using Chroma Key and Chroma Blur in Sony Vegas tutorial. Keith does an excellent job of explaining things.
