Activity › Forums › Boris FX Particle Illusion › How To Turn Off An Emitter..
  • How To Turn Off An Emitter..
    Posted by Cenk Yartan on January 25, 2008 at 11:27 am
    Sometimes i work on a long project and i deal with a lot of emitters. But after a while it slows down because of the emitters. I want to see what im doing not what i did so i was wondering if there is a way to stop Particleillusion from Rendering past emitters while im working on the new ones. It takes a lot of memory for the past ones and just clicking on the little symbol next to the emitter doesn’t do the job. It just makes it disappear not stop rendering.
    Thanks..
    Cenk Yartan replied 18 years, 8 months ago 2 Members · 2 Replies
  • Alan Lorence
    January 28, 2008 at 8:33 pm
    Try using the “active” graph to turn off emitters that are no longer in use.
    Better yet, break your project into several shorter clips (if possible).
    Alan.
    http://www.wondertouch.com
  • Cenk Yartan
    January 28, 2008 at 10:07 pm
    Thank You so much!! Active Graph is working!!
    Thanx..
