Activity Forums Adobe After Effects How to turn a picture wall into a globe. Any suggestions?
  • How to turn a picture wall into a globe. Any suggestions?
    Posted by Coastal on December 22, 2005 at 7:00 pm
    I’ve used some of the tutorials to make a wall of photos and add the shine effect to it. Can anyone suggest a method to tun my flat wall of photos into a spinning globe?
    Dave Beaty replied 20 years, 8 months ago 3 Members · 2 Replies
  • Jonathan Miller
    December 22, 2005 at 8:38 pm
    PreComp the entire thing and then add CC Sphere to that PreComp. The Shine rays might not look right, though, after you sphereize the PreComp, so you might want to add it afterwards (maybe PreComp the Precomp before adding shine.)
    You will probably also have to work on the seam where the edges of the wall come together on the globe, but still, this is probably the easiest way to go.
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
  • Dave Beaty
    December 23, 2005 at 3:05 am
    If your wall of pictures can be made of multiple layers, the 3D Assistants Matrix Creator and Sphereoid Creator plug ins can transform a flat plane of pictures into a sphere of pictures. Use keyframes on the flat wall, then apply the assistant. Digital Anarchy makes the 3D assistants plug-ins.
    Not exactly a globe, but you could transition to a globe of the same size from this effect.
