Activity Forums Adobe After Effects How to travel down a tube/cylinder?
  • How to travel down a tube/cylinder?
    Posted by Scott Wright on October 23, 2008 at 3:42 pm
    Hey there 🙂
    I have to create about a small clip representing the travelling down an electrical wire… like a tube.
    You can see a similar example in the screenshot below, or on the following link:
    See here: About 10sec in: TellyAds Link
    Is there a way to do this in after effects, or do you think it would be easier to create in cinema4D (perhaps going down a cylinder?)
    Thanks for any help in advance!
    Kevin Camp replied 17 years, 10 months ago 3 Members · 3 Replies
  • Steve Roberts
    October 23, 2008 at 5:52 pm
    Use Cinema 4D.
    -sweep NURBS
    – circle
    – spline
  • Scott Wright
    October 23, 2008 at 6:26 pm
    ok cool…. then perhaps copy the spline and use it as a path for the camera too, then just a case of getting a good material and a bit of effect in AE afterwards…
    https://www.scottswork.co.uk
  • Kevin Camp
    October 23, 2008 at 7:06 pm
    for the texture, i would think that the cloud shader with some extreme scaling could produce a similar texture for the material.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
