Activity › Forums › Live Events & Streaming › How to transmit video/audio to overflow audtorium
  • How to transmit video/audio to overflow audtorium
    Posted by Reg Gothard on February 1, 2007 at 5:20 pm
    Re-posted at Mark Suszko’s suggestion from the Event Videographer forum.
    The Principal of one of the high schools that I produce Grad videos for has asked me to set up a link from the Grad ceremony location (a church) to an overflow auditorium (nearby school gym), so people can watch the ceremony on a video screen.
    Distance is in the 150 – 250 metre range.
    I run three cameras at the ceremony. (I’m normally a one man band, but enlist help for the few three-camera shoots that I do.)
    Issues:
    1) Connection – wire or wireless? What are my options for each?
    Wire – What do I need in order to push picture and sound down the same cable (Coax? Twisted pair?) Will I need to amplify the signal? How much quality will I lose over 150-250m?
    Wireless – Outside broadcast equipment is big $$$$. So could I get away with using equipment like the following? Although they’re designed primarily for surveillance, would they be suitable – or am I merely smoking substances that some would like to acquire? 🙂
    Option 1… https://www.microvideo.ca/2400plus.htm
    (This unit has features I don’t need)
    Here are some specs their rep sent me. Unfortunately, I don’t know which specs indicate the quality.
    Transmitter Specifications
    Frequency 2400-2483 MHz
    RF Output Power per FCC part 15.249
    Frequency Stability 0.005% PLL stabilized
    Video Bandwidth 5.8MHz
    Input Impedance 75 Ohms
    Audio Input 1 Vpp line level
    Input Impedance 600 Ohms
    Bandwidth 50Hz-15kHz (3dB)
    Data Connection RJ11 jack for connection to PC with software
    Receiver
    Image Rejection >60dB
    Adj. Ch. Rejection >20dB for adjacent channels, >90dB Ch1-4, >60dB Ch2-4, 3-1
    Receiver Sensitivity -90dBm
    Coding 32 bit code
    Video S/N >40dB at -80dBm RF input signal, >45dB at -75dBm RF input signal
    Audio Output 1.5 Vpp line level, typ.
    Output Impedance 600 Ohms
    Audio Output S/N >12dB at 85dBm RF input
    He also sent me estimated range data, but this post is already long…
    Option 2… https://www.canvidcam.com/product.php?txtCatID=18&txtProdID=62
    This is much more basic, and has a shorter range, but the price is much nicer.
    If this kind of equipment is NOT suitable, can anyone point me to stuff that is?
    2) “Director’s Equipment” – the stuff I need for someone to switch among cameras for transmission to the school gym. I assume I’ll need four monitors (3 source, 1 destination), a video switcher, cabling from cameras to this equipment, and cabling from this equipment to the projection equipment (via the wired or wireless link). Right? Wrong? Did I miss anything?
    I suspect what I want to do is possible but not practicable at the kind of low low budgets a grad class of fewer than 250 can afford. But I wanted to run it by people more experienced than me before replying to the principal.
    Thanks in advance (and sorry about long post)
    Andy Stinton replied 19 years, 8 months ago 2 Members · 1 Reply
  • Andy Stinton
    February 6, 2007 at 8:50 pm
    I will only deal with one aspect of this by saying use wires not wireless especially 2.4Ghz band. It
