Activity › Forums › VEGAS Pro › How to transistion a left to right before and after grading sliding across the screen.
  • How to transistion a left to right before and after grading sliding across the screen.
    Posted by Derek Charles on July 29, 2016 at 10:04 am
    An exact example would be in the intro to this video – I want to show before and after color grading but have it slide like this. Thanks!
    https://www.youtube.com/watch?v=tia2IOqNJE0
    Graham Bernard replied 10 years, 1 month ago 3 Members · 4 Replies
  • Graham Bernard
    July 29, 2016 at 10:33 am
    Easy.
    In PAN/CROP use an Animated Mask and have the Mask “Apply to FX” set to YES.
    Takes about 2 mins to setup.
    * Grazie
  • Edward Troxel
    August 6, 2016 at 5:14 pm
    Or, have the event without an effect and then overlap with the event with the effect and change the transition to a wipe.
    Edward Troxel
  • Derek Charles
    August 17, 2016 at 9:38 am
    I must admit, I am still very confused on what to do.
  • Graham Bernard
    August 17, 2016 at 10:23 am
    [Derek Charles] ” I am still very confused on what to do.”
    Understood. If it should help I’ve attached my approach to this. Just ADD as a Take any of your media and you will see the Black and White SONY Fx will scan across.
    Here’s the result:
    Here’s the VEG file for you
    10424_movingfx1a.veg.zip
    * Grazie
