Activity Forums Adobe Photoshop How to touch up ?
  • How to touch up ?
    Posted by Mills_mg on May 16, 2005 at 4:17 am
    hello everybody,
    just wondering abt. is there any way to properly touch up a Blured photo taken by my mobile CAM?
    The pic is quite blurred. I tried a lot with brightness and variations but couldnt work well! Any specific technique or steps available to clear this ?
    –thank you
    Jeff Kelley replied 21 years, 4 months ago 3 Members · 3 Replies
  • Kelly Johnson
    May 16, 2005 at 4:29 am
    Most of the time, the specific photo needs to be seen to determine how bad and what the best means would be.
    However, sometimes in the transfer to photo cd’s, a channel can offset and give a pusedo-color cast that looks like blurring. So, check the individual channels first to see if you need to nudge one some direction.
    Something I’ve had pretty good success with is using the Smart Blur filter then the Unsharp Mask. Different recipes for different items, but short of exact selections and massive retouching via rubberstamping, contrast/level adj’s and the like those might help you out.
  • Mills_mg
    May 16, 2005 at 7:05 am
    Oh Thnx !
    I used Smart Blur filter then the Unsharp Mask as u said but still its not that effective ? Still the blurred areas are there.
    Any other way around here?
    Thank you.
  • Jeff Kelley
    May 16, 2005 at 3:10 pm
    I think one would have to see the image in question to give you any answer. It’s like telling a doctor over the phone that you don’t feel well and expecting him to tell you how to cure yourself.
