Activity Forums VEGAS Pro how to temporarily bypass an audio effect?
  • how to temporarily bypass an audio effect?
    Posted by Gilles Gagnon on February 1, 2010 at 9:37 pm
    I’m using an effect on a track and only want to have it ON for a few minutes then off again for the rest of the track.
    I don’t want to automate the effect’s various settings, simply to turn it off (“automate a bypass”) for a bit.
    How do I accomplish this?
    Gilles
    John Rofrano replied 16 years, 7 months ago 2 Members · 1 Reply
  • John Rofrano
    February 1, 2010 at 9:52 pm
    Bypass is one of the automation parameters. If you want to automate the bypass you need to add an automation envelope for it. Right-click on an empty part of the audio track and select FX Automation Envelopes | FX Automation. Then select the Bypass parameter and place keyframes on the envelope to turn it on and off.
    Alternately you could split the audio event at the point that you want to add the FX and add a “non-realtime effect” to just that section of the clip. You could also isolate that part of the audio on a separate trace and apply the FX to that track.
    There are lots of ways to do this but automation is probably the easiest way.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
