How to Tell What Version of BCC AVX You’re Running?
Posted by Peter Moretti on November 27, 2009 at 6:34 pmI am having some problems upgrading to BCC 5.0.4. I’ve downloaded the 5.0.4 update but Avid says it will only work if I’m currently running 5.0.3.
How can I reliably tell what version of BCC I currently have installed on my computer?
Thanks much.
Matt Mullen replied 16 years, 9 months ago 2 Members · 7 Replies -
Matt Mullen
November 30, 2009 at 4:57 pmWhat version of “Avid” are you running and what OS are you on.
My hunch is that 5.0.4 should be perfectly fine.
-Matt
Peter Moretti
December 13, 2009 at 4:45 pmMatt,
Thank you very much for the response. I’m running MC 3.1.1 on Win XP 32-bit.
My problem is that the 5.0.4 installer is an update (not a full package) that will only run properly if 5.0.3 is already installed. But I don’t know if 5.0.3 is installed or not.
Anyway to find out for certain what version I’m currently running?
Thanks again.
Matt Mullen
December 14, 2009 at 12:37 amThe update should run fine as long as you have any version of BCC 5.
Have you run the installer? Are you running into an issue?
-Matt
Peter Moretti
December 14, 2009 at 6:31 pmMatt,
I downloaded the installer from Avid. It’s rather small (around 56MB) and Avid’s website says 5.0.3 needs to be installed before running it. I tried running it anyway, but nothing happened. Someone suggested that I try choosing the Repair option when installing, but I don’t know if that’s the correct thing to do.
I tried downloading 5.0.4 directly from the Boris FX website, but all the 5.0.4 links are broken (Windows and Mac). All the other BCC AVX updates download fine, so I think there is an issue w/ the Boris website.
Thanks much for your help.
Peter Moretti
December 15, 2009 at 3:40 amThanks Matt, Repair did something, so I’m assuming it worked. Thanks again.
Matt Mullen
December 15, 2009 at 2:29 pmNot a problem. Let me know if you have any other questions.
