Activity › Forums › Panasonic Cameras › How to tell mxf audio vs. mxf video file
  • How to tell mxf audio vs. mxf video file
    Posted by Todd Mcmullen on April 27, 2006 at 10:47 pm
    Other than possibly size of file, is there a way to tell the difference in an mxf file. I have a hard drive that went nuts and sent files all over the place. The data is there, it is just not in the proper folders. I am tryin to trick it and rebuild some of the files in the folders. I know, Iknow…..
    also, is there any program, avid, etc, that can just simply import or open mxf files. I know fcp 5.04 only imports p2. It does not allow a file or folder import.
    tanks
    Todd McMullen
    Flip Flop Films
    Austin
    Cinematography Forum Leader
    Mike Schrengohst replied 20 years, 5 months ago 5 Members · 8 Replies
  • 8 Replies
  • Noah Kadner
    April 28, 2006 at 4:08 am
    Size would be the obvious one.
    Noah
  • Shane Ross
    April 28, 2006 at 7:20 am
    And yes, Avid does read MXF files natively. But I am not sure if it can with them scattered everywhere. Once that happens your data is scattered, and might be tough for any application to read.
    But I can’t say for sure. I haven’t used Avid to read MXF files.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Barry Green
    April 28, 2006 at 7:41 am
    Actually it’s really easy to tell the MXF audio files apart from the MXF video files.
    They’re named differently.
    The video files use a six-character base name, the audio files use eight (the last two characters being the digits 00, 01, 02, and 03, to differentiate which audio track that MXF file represents).
    So if you had a clip with a base name of:
    0021R5.mxf
    then the audio files would be:
    0021R500.mxf
    0021R501.mxf
    0021R502.mxf
    0021R503.mxf
    Get the most from your DVX camera. The DVX Book and DVX DVD are now available on ebay and at Amazon (https://www.fiftv.com/db)
  • Shane Ross
    April 28, 2006 at 7:44 am
    Thanks Barry.
    I just landed back home from NAB and was too tired to go look at my master MXF files to confirm anything.
    And I only worked TWO days. You did the entire show. oof.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Todd Mcmullen
    April 28, 2006 at 1:16 pm
    thanks barry,
    this will help. Does the new fcp universal read mxf files any better?
    Todd McMullen
    Flip Flop Films
    Austin
  • Mike Schrengohst
    April 28, 2006 at 3:54 pm
    FCP 5.1 is the same as 5.0.4 when it comes to .mxf,
    I have also ordered Canopus and use the P2 viewer on the
    PC all the time. Once you get the P2 info to QT in FCP
    it is easy to edit. I am receiving .mxf files and need
    something that will read them as well. I have used Raylight
    with Vegas also.
    Mike Schrengohst
    http://www.MotionZoneHD.com
  • Noah Kadner
    April 28, 2006 at 5:09 pm
    There’s also HDLOG on the Mac side for direct MXF, metadata access but it’s quite expensive IMHO.
    https://www.imagineproducts.com/hdlog.htm
    I would be a little surprised if the next major release of FCP did not include direct MXF editing and metadata handling.
    Noah
  • Mike Schrengohst
    April 28, 2006 at 6:22 pm
    That would be great, support for 720/25p is also needed!
    Mike Schrengohst
