Activity › Forums › VEGAS Pro › How to tell if a clip is HD
  • How to tell if a clip is HD
    Posted by Linda O’connell on April 5, 2010 at 2:42 pm
    I imported a bunch of clips for a customer from a Hard Drive Camera. Now Vegas is crashing all the time and won’t render. I have tried to figure this out and wondering if my problem may be that these clips are HD.
    Is there a way to tell? When I imported them, I basically click and drag.
    (I have worked on other Vegas projects during this fiasco and they are working fine, so I know it’s something to do with these clips.)
    John Rofrano replied 16 years, 6 months ago 4 Members · 5 Replies
  • Scott Francis
    April 5, 2010 at 3:32 pm
    When you click on the clip in the explorer window, at the very bottom of that window it will give you all the clips attributes. Dimensions, sample rate for audio, etc.
    Scott Francis
    Mind’s Eye Audio/Video Productions
  • John Rofrano
    April 5, 2010 at 5:54 pm
    You can also right-click the clip in the project media or an event and look at the properties. It should tell you the codec and dimensions there.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Greg Porter
    April 5, 2010 at 6:54 pm
    ….And should you change your Project Properties to match the properties of the supplied video?
    I just realized that most of my customers’ supplied film was 720×480 Widescreen and I’ve been using the default “Project Properties” settings (720×480) and rendering in the the default .avi settings (720×480).
  • Linda O’connell
    April 5, 2010 at 8:11 pm
    Under Media it says this:
    Stream: Video 1
    Format: MPEG-2
    704 x 480×32
    Frame Rate: 29.97
    Under General it says this:
    Folder: C:Desktop\Olson\2010
    Type: MainConcept MPEG-2
    Size: 77.42 MB (79,282,176 bytes)
    Streams
    Video: 00:02:00.120, 29.970 fps interlaced, 704x480x32, MPEG-2
    Audio: 00:02:00.128, 48,000 Hz, Stereo, MPEG
    Does any of this mean anything to anyone? It might as well be in Greek to me!
  • John Rofrano
    April 6, 2010 at 3:12 am
    There is no way to tell if it’s widescreen from those attributes because the pixel aspect ratio is not listed. The video is, unfortunately, only DVD quality MPEG2 which will degrade when you re-render it to produce your final output. This is less that optimal but if it’s what they gave you, then that’s what you have to work with.
    ~jr
