Activity Forums Apple Final Cut Pro Legacy How to take a Freeze Frame from FCP to Photoshop
  • How to take a Freeze Frame from FCP to Photoshop
    Posted by Gcode9 on February 1, 2006 at 10:36 pm
    It seems like I had this technique down, but a month away from FCP has me stumped on this one. I want to take a Freeze frame still from my source footage (timeline) and export/import the still frame into Photoshop. Does any have any suggestions. Your assistance is very much appreciated.
    gees
    Will Keir replied 20 years, 7 months ago 4 Members · 4 Replies
  • Shane Ross
    February 1, 2006 at 10:42 pm
    Mark IN and OUT on the spot you want.
    Go to FILE>EXPORT>QUICKTIME CONVERSION
    Change from QUICKTIME MOVIE in the dropdown menu, to STILL IMAGE.
    Set it to what format you want.
    Export.
    You will most likey have to de-interlace in PS.
    Shane Ross
    Alokut Productions
    http://www.lfhd.net
  • Will Keir
    February 2, 2006 at 8:27 am
    You can do it even quicker but putting the playhead at the spot you want to picture taken, then do the steps mentioned above.
    A few things to note. If you don’t have Photoshop on the same computer your have Final Cut Pro, there is a De-interlace filter in your effects bin.
    Now I don’t know much one is best for quality, maybe Shane does, or someone else that might post here and inform me.
    Trouble with Stills:
    I found that the still’s I exported where a bit squashed. I had a 16:9 timeline with 16:9 shots, that could be the reason why, and if someone could help me in this area.
    How do I get the exact same frame I am seeing in my final cut pro timeline as a still JEPG image?
    Will
  • Chris Poisson
    February 2, 2006 at 3:22 pm
    Will,
    In Photoshop, you must change the height to 540 and it will look normal. This holds true for making DVDSP menus from your sequence.
    Have a wonderful day.
  • Will Keir
    February 14, 2006 at 10:11 am
    Chris, I tried what you said, I went in photoshop and under image I tried to change to photo, but I couldn’t unlink height and width, so I made the picture 540 heights but the width went down too. So no solution to squashing with regard to your suggestions, but thanks anyway for trying.
    Will Keir
