Activity › Forums › Adobe After Effects › how to switch off a layer ?
  • how to switch off a layer ?
    Posted by Jerry Yang on August 1, 2012 at 12:43 am
    is there a way to temporarily switch off a layer along the timeline?
    say i want it to show for 3 sec and disapear for 5 sec and show again
    for some time. or would you rather copy the layer and ajust each of its timespan? and what is a good approach to apply more effects on one layer on different time mark?
    Roland R. kahlenberg replied 14 years, 2 months ago 3 Members · 5 Replies
  • Brian Charles
    August 1, 2012 at 12:48 am
    [Jerry Yang] “say i want it to show for 3 sec and disapear for 5 sec and show again
    for some time.”
    Keyframe the opacity value of the layer. Zero opacity = invisible layer. To avoid ramping the layer up and down use hold keyframes.
    It sounds like you could benefit from some After Effects basic training.
    See here:
    https://www.videocopilot.net/basic/
  • Jerry Yang
    August 1, 2012 at 12:56 am
    thanks Brian, i should have explained it better as i dont just wanna play with opacity(for which i use strobe light effect for), but more for applying different effects or things on one layer. and i thought coply layers and ajust their timespan along the timeline is a bit tedious.
  • Brian Charles
    August 1, 2012 at 1:08 am
    What about an adjustment layer?
    Or a Parented Null Object that controls the layer’s effects?
  • Jerry Yang
    August 1, 2012 at 1:14 am
    great! i will dive in to those 2 topics, thanks for your pointers.
  • Roland R. kahlenberg
    August 1, 2012 at 2:12 am
    Use Hold KFs on the Opacity property. Specifically, you only need two values, 100 and 0 to effectively switch on and off the layer’s visibility. This is an elegant and easy option to apply.
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
