Activity › Forums › Adobe After Effects › How to stop slowly an expression?
  • How to stop slowly an expression?
    Posted by Daniel Gómez on May 27, 2013 at 1:41 am
    Hello everyone!
    I’ve created a composition with a small square inside. I want this square to rotate just 5 seconds, so I’ve made this expression to rotate the layer 72 degrees per second:
    if (time <5) time*72 else 0
    It works perfectly, but I wonder if there is any way to make the square stop slowly and not that abrupt.
    Sorry for my english and thank you very much for your time 🙂
    Daniel Gómez replied 13 years, 4 months ago 3 Members · 4 Replies
  • Tero Ahlfors
    May 27, 2013 at 7:04 am
    Maybe you could link the expression to a slider control.
  • Daniel Gómez
    May 27, 2013 at 12:08 pm
    Thank you very much for answering 🙂
    I tried to build the expression linking it to a slider control, but I’m not getting what I need. Not because After Effects; because of me, of course.
    This is my project, right now: 6062_rotatingsquare.aep.zip
    I want the square to be rotating regularly until it gets the second number five, where it’s going to stop slowly, as if I’d used “Easy Ease In”.
    Hope I explained well. Thanks a lot again!
  • John Cuevas
    May 27, 2013 at 1:58 pm
    Try using an easeOut expression on your rotation: easeOut(time, 0, 5, 0, 360)
    I made a simple project using one, but did it over 20 seconds, because over 5 seconds, it seemed too fast: 6065_easeoutcs5.5.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Daniel Gómez
    May 28, 2013 at 10:43 am
    So helpful! Thank you very much. I appreciate your help 🙂
