Activity Forums Adobe After Effects Expressions How to start an animation on event?
  • How to start an animation on event?
    Posted by Taras Kosmachuk on November 14, 2013 at 7:28 pm
    Hi!
    I have a layer with an animation and a null object. I need to set the animation to start when the null passes anchor point of the layer on x axis…
    Here’s the overall algorithm that I’m using but the problem is that I don’t know how to find the time when above condition happens!
    nullObject = thisComp.layer(“null”);
    nullObject = nullObject.toWorld(nullObject.anchorPoint);
    layPos = thisLayer.toWorld(thisLayer.anchorPoint);
    trackValue = layPos[0]-nullObject[0];
    if (trackValue <= 0) {
    t = ??? // algorithm to find time…
    } else {
    t = time;
    value=value.atTime(t);
    Can anyone help me with this?
    Thanks in advance!
    Taras Kosmachuk replied 12 years, 8 months ago 2 Members · 4 Replies
  • Dan Ebberts
    November 14, 2013 at 8:47 pm
    Your expression needs to start at the current frame and go back in time frame-by-frame, until you find the most recent frame where the null’s x went from being less than the target x to more than the target x. Then subtract the time of that frame from the current time to determine how long your animation has been running.
    It’s really just a threshold detector along the lines of this beat detector:
    https://www.motionscript.com/design-guide/audio-trigger.html
    Dan
  • Taras Kosmachuk
    November 19, 2013 at 1:07 am
    Hi Dan! Thanks for helping me out!
    I’ve adapted your expression to my needs and it seems to be correct, it should return time when layer x position is less or equal to null x position… But ae returns an error:
    “Function trackValue.valueAtTime is undefined”
    What am I doing wrong?
    goalNull = thisComp.layer("null");
    goalPos = goalNull.toWorld(goalNull.anchorPoint);
    trackValue = layPos[0]-goalPos[0];
    check = false;
    for (f = 0; f &lt;= timeToFrames(); f++){
    t = framesToTime(f);
    if (trackValue.valueAtTime(t) &lt;= 0 ){
    check = true;
    break;
    if (check)
    t;
    else
    time;
  • Dan Ebberts
    November 19, 2013 at 1:57 am
    I haven’t tested this, but I think you need to move some of your code inside the loop and use the time parameter of toWorld() to get the time-appropriate values:
    check = false;
    for (f = 0; f <= timeToFrames(); f++){
    goalPos = goalNull.toWorld(goalNull.anchorPoint,t);
    layPos = toWorld(anchorPoint,t);
    if (trackValue <= 0 ){
    check = true;
    break;
    if (check) t else time;
    Dan
  • Taras Kosmachuk
    November 19, 2013 at 2:49 am
    It works just perfect! Thanks a lot!
