Activity › Forums › Adobe After Effects › How to “Spray” Artwork Onto a Surface
Posted by Lillian Young on July 20, 2009 at 5:38 pmI am using AE CS3/4, and I need to break up pieces of an image, then spray them onto a surface like spray paint or make them jump from space onto the object so that it’s very energetic.
I am going to explore options, but I thought I’d check here as well in case someone has done this before and has a suggestion.
* No Expressions please – I don’t know how to do expressions *
Thanks in advance!
Joey Burnham replied 17 years, 2 months ago 4 Members · 8 Replies -
Brian Charles
July 20, 2009 at 6:52 pmThere’s a tutorial on this site that does what you describe.
The sample is here: https://www.ayatoweb.com/ae_tips_e/ae52_mov08_e.html
The tutorial here: https://www.ayatoweb.com/ae_tips_e/ae52_e.html#
David Bogie
July 20, 2009 at 8:00 pmSo many excellent tutorials out there, so little time to find and play them all.
bogiesan
Lillian Young
July 20, 2009 at 8:17 pmThanks. I am stuck at Step 4 – In the Fractal Noise effect panel, my Scale Width and Scale Height are grayed out.
I am trying these shatter techniques in the meantime
Shatter
https://www.youtube.com/watch?v=kkID0QZ31EsReverse Shatter
https://vimeo.com/groups/6404/videos/4674373Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Lillian Young
July 20, 2009 at 8:18 pmI have to submit this asap, which is why walking through a tutorial for hours only to get stuck near the last step or for it not to work is a pain.
David Bogie
July 20, 2009 at 11:17 pm[Lillian Young] “I have to submit this asap, “
This is a well known disaster around here. Lots of newbies open up After Effects and explore a 3D particle system with ballistics and fractals for the first time against a deadline.
The process of learning to apply the ballistics backwards is not covered in the tutorial Brian pointed you to. That’s another long topic, learning how to predict how Shatter will perform running backwards.
We wish you luck but I think most of us used Shatter on twenty or more projects before we got friendly with it. It’s what we call a “complicated filter.”
bogiesan
Lillian Young
July 20, 2009 at 11:43 pmThanks, Brian. I may give it another go.
For now I’m trying to create a splattering paint effect, like the paint is splashing the image onto a surface. I am using the Vector Paint plugin, and reversing it over the surface. That looks kinda cool to me, but I’m continuing to search for that ‘splash’ on look.
I may need to break up the art, add puppet points to give the pieces a wobble effect, and fly them in 3D space to the surface where they rejoin as one piece.
I don’t know. I think there has to be a simpler way.
Joey Burnham
July 21, 2009 at 5:27 pmYou could get some black / white footage of paint splats (video copilot has them in the riot gear efx package) and use that as a track matte for your video footage. So it would “splat” your footage onto the screen.
Joey
