Activity Forums Avid Media Composer How to smooth skin?
  • How to smooth skin?
    Posted by Milton Hockman on March 19, 2008 at 8:53 pm
    I have an interivew I want to smooth the skin of. It’s an older woman. What filters and settings should I use to make her wrinkles not as bad?
    Motion Graphics Artist and Non-Linear Editor
    Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more.
    Dan Warvi replied 18 years, 6 months ago 6 Members · 6 Replies
  • David Braswell
    March 19, 2008 at 9:53 pm
    If you own Genarts Sapphire plugins, I’d play with the Film Effect. You don’t have to go for that super glossy, saturated look. Rather, work with the glow, glow width, and grain blur settings. Barring Sapphire, you can try glow in Boris or AE.
  • Michael Hancock
    March 19, 2008 at 10:03 pm
    Sapphire also has a great Soft Focus plugin that’s perfect for this kind of thing. Otherwise, you could double up the video, add a slight blur to the top layer, add a Transfer effect, set it to screen, then lower the opacity. It will give everything a softer, dreamier look.
    Michael.
  • Jean-marc Manivet
    March 20, 2008 at 12:37 am
    My tip,
    V1, Video of the lady with an exagerate glow
    V2, same path of video duplicated with this time a chroma key using color of the lady’s skin. Adjust how you want to smooth with tolerance …etc parameter.
    Sorry for my french English.
    Jean Marc
  • Andrew Kimery
    March 20, 2008 at 5:13 am
    If you have access to FCP there is a niftly plug-in called Electronic Make-up Artist you could give a whirl.
    https://straylight.tv/pluginz/index.html
    -A
  • Milton Hockman
    March 20, 2008 at 2:29 pm
    how do i do a transfer mode in avid?
  • Dan Warvi
    March 20, 2008 at 5:11 pm
    Well, it’s called something else now…Digital Film Tools had the awesome 55mm plugins for Avid (which had a both a skin smoother and a selective soft focus) but Tiffin bought those plugins and turned them into Dfx:
    https://www.tiffen.com/dfx_filter_effects_ig.html
    Dan Warvi
    After Effects, Avid, Motion, Broadcast Systems & PC as nec
