Activity Forums Adobe After Effects how to show motion in static image
  • how to show motion in static image
    Posted by Ucanwinu on September 13, 2005 at 9:33 pm
    hi list
    i have a still shot where some people are standing. in the background are some grass and reeds.
    what can i do to make those grass reeds sway like some light air is blowing.
    is displace is the answer. i tried it but not with much help. can u explain in detail how can achieve this effect.
    similarly i would like to do in another image with some calm sea waves in the background. i would also like these waves to move too.
    plz reply asap
    thanks and regards
    Ace Billet replied 21 years ago 3 Members · 2 Replies
  • Jim Kanter
    September 14, 2005 at 2:50 am
    You will need to duplicate the layer, mask the top layer to reveal the static portions (people standing still, etc.) and then use an animated displacement map (or other effect like bulges or ripples) on the duplicated layer below.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Ace Billet
    September 14, 2005 at 2:13 pm
    Also if you use displacement map be sure to precomp the “Map” Layer,
    and then feed tis channel to the grass layer with the disp map effect.
    Feed me weird things..
    cheers
    ace
