Activity Forums Adobe Premiere Pro How to sew together multiple hi-def files?
  • How to sew together multiple hi-def files?
    Posted by Michael Dean on March 2, 2011 at 8:46 am
    Hello!
    I’ve got a 99-minute show, created as 16 separate projects (each one is one DVD chapter). The project is 1280 x 720, 59.94 FPS. Made it in Premiere Pro Cs5. Running Windows 7 with 4 gigs of RAM (my computer cannot accept any more). Media and scratch is on two external eSATA drives.
    I have no problem outputting the separate chapters as 16 DVD files and authoring a really good looking DVD in Encore. But the distributor also wants a single hi-def (1280 x 720, 59.94 FPS) file, one 99-minute file, for Netflix and iTunes delivery. h.264 or standard MPEG is acceptable.
    I tried importing all the sequences into one project, it kept crashing. I was able to output 16 separate hi-def files, but they need one file. When I tried a test importing two of the hi-def files into a new Premiere Project and exporting with “Match Sequence Settings” and “Use Maximum Render Quality”, the quality was degraded a bit in the output.
    Any ideas for how to sew these 16 chapters together? Perhaps something I can change in Premiere’s export settings? Or is Premiere not the best choice for this…is there another utility that would do it better?
    Thank you very much!
    Michael
    Ann Bens replied 15 years, 6 months ago 3 Members · 3 Replies
  • Angelo Lorenzo
    March 2, 2011 at 9:00 am
    I would say try this first:
    1. Make a copy of all project files involved.
    2. Open each copy and run Project > Remove Unused.
    3. Import these “cleaned” projects into a single new project.
    Failing that, what are you exporting your 16 sequences to? If you don’t have access to an intermediate codec, I suggest exporting to MOV with the Animation codec at 100% or the JPEG2000 codec at 100%. If you want to go h.264, I wouldn’t go any lower than 45mbps if it has to go through another round of compression for something of decent quality. You can then export them, bring the 16 files into a project, string them in a timeline, export the deliverable and call it a day.
  • Michael Dean
    March 2, 2011 at 9:05 am
    Thank you! I removed all unused before any outputting, but will try the second suggestion.
    Michael
  • Ann Bens
    March 2, 2011 at 11:31 am
    Don’t use Match Sequence Settings it’s likely set to the wrong codec. Use a preset or do it manually.
