Activity › Forums › Maxon Cinema 4D › How to set the default behavior of tools
  • How to set the default behavior of tools
    Posted by Dustin Bowser on July 24, 2010 at 10:41 pm
    I’ve been wondering this for a while. Is there a way to set the default behavior of a tool, so that in the future any time you use it it always acts the way that you intended, and it’s up to you to go in and change it if you want it to behave any differently?
    An example of this is the “Rectangle Selection”. I would like to be able to make it so “only select visible elements” is NEVER on when using the Rectangle Selection. Usually I don’t want this on, so I would like to make this the default setting, and I can go in and tick it back on if I need to. For some reason, “only select visible elements” is ON by default. Is there any way to change this?
    Brian Jones replied 16 years, 2 months ago 2 Members · 1 Reply
  • Brian Jones
    July 25, 2010 at 12:02 am
    check out Special Initialization Files in the help. template.c4d and new.c4d will save that.
