Activity › Forums › Adobe After Effects › How to set accurately the Region of Interest
  • Roei Tzoref
    November 6, 2017 at 12:52 pm
    [Yaniv Cahoua] “is there a way to set accurately the region of interest by entering values for the position width and height ?”
    as a pre-process? unfortunately No. you can see what they are but not enter them:
    as a post-process, you can access it in the render settings but I find it useful for just using the render queue to render the crop area and see the measurements…
    and as Dave says, if you want to change the composition dimensions, you should do this in the composition settings.
    feel free to ask for this feature and make Ae better for all of us: https://www.adobe.com/products/wishform.html
    Roei Tzoref
    2D/VFX Generalist & Instructor
    ♫ AeBlues Tutorials ♫
    http://www.tzoref.com
  • Kevin Camp
    November 6, 2017 at 7:57 pm
    you can show the ruler (view>show ruler) which can help in drawing the region of interest, then crop the comp, then go into the comp settings and make them exact…
    Kevin Camp
    Art Director
    KCPQ, KZJO & KRCW
  • Mikhail Vasilev
    December 25, 2019 at 3:54 pm
    Move your Region to the left-top corner
    Resize it as u need, you will find exact dimensions/size of it on the Info Panel(it will go from zero, which is convenient)
    After size set Move it to the position u need, use its border to grab it to avoid shape/size destortion
    Done!
  • Richard Garabedain
    January 2, 2020 at 6:05 pm
    the region on interest is a useless function in after effects…dont bother with it
