Activity Forums Adobe After Effects Expressions How to set a wiggle range between two values in Trim Path?
  • How to set a wiggle range between two values in Trim Path?
    Posted by Samith Ahmedh on December 22, 2020 at 5:26 pm
    How do I create a wiggle expression between two values in a line layer. Like between the values 80 to 100 without allowing the wiggle expression to overlap 100 which makes the link stuck.
    Samith Ahmedh replied 5 years, 9 months ago 2 Members · 2 Replies
  • Othman Ahmed
    December 22, 2020 at 6:51 pm
    I think this is what do you want.
    Code :
    aMin = 80; // Use any number you want here as the minimum value
    aMax = 100; // Use any number you want here as the maximum value
    wigFreq = 25;
    wigAmpl = 250;
    w = wiggle(wigFreq,wigAmpl);
    clampIt = clamp(w,aMin,aMax)
  • Samith Ahmedh
    December 22, 2020 at 7:06 pm
    The code works fine in sticking between the values, especially above 80 but still is stuck at 100 occasionally like the normal wiggle expression. I reduced the frequency and amplitude to see if that was the issue but it wasn’t. Appreciate your response and time.
