Activity Forums Apple Final Cut Pro Legacy How to set a “transition” default setting
  • How to set a “transition” default setting
    Posted by Anne-marie on November 22, 2005 at 3:53 pm
    Ok, it’s nothing
    but I like to know how to do it !
    If for exemple I want a “Blur” transitions 30 times in my sequence…
    for 20 second
    with -1 ease in
    .65 ease out
    87 A blur
    19 B Blur…
    do I always need to set the details in the viewer every times I use a transition or I could ask FCP 4.5 to remember my setting?
    It’s the same for the “Mate Generator” (down right of the viewer)
    THE DEFAULT COLOR IS ALWAYS GREY, i have’nt found anything else to change that seting and every days..I’m looking for white or black or blue…
    So If one of you have an idea
    That could help me a lot
    tank you
    L’
    Dean Sensui replied 20 years, 10 months ago 3 Members · 2 Replies
  • Nathan Seay
    November 22, 2005 at 4:41 pm
    Set up the details for the effect in the Viewer, then drag the effect into your favorites. To set as default, control-click the effect and set it as default.
  • Dean Sensui
    November 22, 2005 at 9:04 pm
    Once you set it you can take the one you set and drag it into a bin.
    It won’t be a default setting but it’ll be readily at hand.
    Dean Sensui — http://www.HawaiiGoesFishing.com
