Activity › Forums › VEGAS Pro › How To: Separate settings on separate tracks
  • How To: Separate settings on separate tracks
    Posted by Kelly Griffin on January 10, 2014 at 5:03 am
    I have a rendered animation with alpha that I’ve laid on a track. On that track I want to use the alpha for a composite, and I’ve selected “Premultiplied” for it.
    I’ve put the same animation on a separate track just below it, for which I DON’T want to use the alpha– at a certain point I want to fade full RGB color underneath the partially-transparent identical track.
    My problem is that if I change “Premultiplied” to “Undefined” (or anything else) on one track, it changes to that for both tracks.
    How do I keep one setting on one track and the other setting on the other track?
    –KG
    Steve Rhoden replied 12 years, 8 months ago 3 Members · 4 Replies
  • Steve Rhoden
    January 10, 2014 at 7:26 am
    Simply make a copy of the same animation and rename it, so when
    you have them on the track, they are actually two separate events,
    where changing the alpha channel in one wont affect the other.
    Steve Rhoden
    (Cow Leader)
    Film Editor & Compositor.
    Filmex Creative Media.
    https://www.facebook.com/FilmexCreativeMedia
    1-876-461-9019
  • Kelly Griffin
    January 10, 2014 at 5:53 pm
    Hmm, okay, but that just seems peculiar.
    Maybe there’s some advantage to NOT being able to use the same element in a different way on a different track, but it’s not occurring to me what that might be.
    –KG
  • Aleksey Tarasov
    January 10, 2014 at 8:00 pm
    Right click on the second event and choose Create Subclip. Now set the desired media properties
    Sony Vegas Templates
  • Steve Rhoden
    January 11, 2014 at 12:46 pm
    Yes, the subclip feature can also be used.
    Steve Rhoden
    (Cow Leader)
    1-876-461-9019
