Activity Forums Adobe Premiere Pro How to separate audio channels?
  • How to separate audio channels?
    Posted by Richard Lapthorn on August 29, 2011 at 2:54 pm
    Hi guys, I’m a new Premiere user coming from Avid and I have some confusion working with audio right now.
    I filmed some interviews with a radio mic on channel one and channel two was recording from the onboard mic. In Premiere I want to bin the second channel and pan the first channel across left and right. The problem is I haven’t got a clue how to do so! This was a doddle in Avid and I’m sure it’s easy in Premiere.
    Could someone give me a hand here?
    cheers
    Rich
    Ben G unguren replied 15 years ago 2 Members · 2 Replies
  • Richard Lapthorn
    August 29, 2011 at 3:28 pm
    Edit; I managed to find out how to do it. Basically, I should have mapped out the audio of the clips before I put them on the timeline, by right clicking and modifying, then changing the stereo track to two mono tracks… Et Voila.
    However I had already finished the edit and was planning to fix the audio once finished as I always have done with Avid. There is a workaround for this; an audio effect called fill left or fill right, which duplicates the right channel to the left or vice versa.
    Hope this is useful to someone else
  • Ben G unguren
    August 29, 2011 at 5:01 pm
    Thank you Richard! I hadn’t noticed that filter before. cheers
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
