How to send error reports using PRS
When using Vegas Pro 14, if an error occurs, a PRS Problem Reporting Service window will appear. To send that error report to VEGAS support, place a check in the box to show problem details, then hold down control and shift on your keyboard while clicking send. This will cause the report to be zipped and a message will appear alerting you to where this report exists on your hard drive. You may then attach the report to your support ticket.
